YAKOV#1
дизель 6.7 2010 год
Раздел «Дизельные двигатели». Тема открыта 10 октября 2012 года, в ней 30 сообщений.
Отче, пургу не гоните в неокрепший разум. Это тут вообще не причем. Под эту пластмасску надпись таковаotez_pimen пишет:Бортовой компьютер посчитал моточасы и по результатам рекомендует поменять этот фильтр. Но я рекомендовал бы (при условии сохранения EGR) воспользоваться этим комплектом
Надпись сбрасывается диагностическим компом.
Perform Service Indicator
Your vehicle will require emissions maintenance at a set
interval. To help remind you when this maintenance is
due, the Electronic Vehicle Information Center (EVIC)
will display “Perform Service”. When the “Perform Service”
message is displayed on the EVIC it is necessary to
have the emissions maintenance performed. Emissions
maintenance may include replacing the Closed Crankcase
Ventilation (CCV) filter element, cleaning of the EGR
Cooler, and cleaning of the EGR Valve. The procedure for
clearing and resetting the “Perform Service” indicator
message is located in the appropriate Service
Information.
Exhaust System – Regeneration Required Now
“Exhaust System – Regeneration Required Now” will be
displayed on the overhead console of your vehicle if the
exhaust particulate filter reaches 80% of its maximum
storage capacity. Under conditions of exclusive short
duration and low speed driving cycles, your Cummins
diesel engine and exhaust after-treatment system may
never reach the conditions required to remove the
trapped PM. If this occurs, the “Exhaust System – Regeneration
Required Now” message will be displayed in the
EVIC. If this message is displayed, you will hear one
chime to assist in alerting you of this condition
By simply driving your vehicle at highway speeds for as
little as 45 minutes, you can remedy the condition in the
particulate filter system and allow your Cummins diesel
engine and exhaust after-treatment system to remove the
trapped PM and restore the system to normal operating
condition.Exhaust Filter XX% Full
Indicates that the Diesel Particulate Filter (DPF) is approaching
full.
Exhaust System – Regeneration in Process
Indicates that the Diesel Particulate Filter (DPF) is selfcleaning.
Maintain your current driving condition until
regeneration is completed.
Exhaust System – Regeneration Completed
Indicates that the Diesel Particulate Filter (DPF) selfcleaning
is completed. If this message is displayed, you
will hear one chime to assist in alerting you of this
condition.
Service Required – See Dealer Now
Regeneration has been disabled due to a system malfunction.
At this point the engine PCM will register a fault
code, the instrument panel will display a MIL light.
CAUTION!
See your authorized dealer, as damage to the exhaust
system could occur soon with continued operation.
Exhaust Filter Full – Power Reduced See Dealer
The PCM derates the engine in order to limit the likelihood
of permanent damage to the after-treatment system.
If this condition is not corrected and a dealer service
is not performed, extensive exhaust after-treatment damage
can occur. In order to correct this condition it will be
necessary to have your vehicle serviced by your local
authorized dealer.
555 (Сергей) пишет:оттепель похоже уже не поможет. Тут уже электроника не даст выкрутиться.
Для понимания процесса, чтоб клубни понимали, когда пора завязывать с экосистемами: какой пробег, давно ли в России, где эксплуатировалась, типы поездок и их соотношение. Где заправлялись? Какое масло?
555 (Сергей) пишет:Поздравляю, что отлегло.
Но из твоего и опыта камчадалов ясно - регенерации на морозе не происходит или идет недостаточно эффективно.
В общем избавляться надо от этой хрени (DPF)
sync79 пишет:если удалять ЕГР то правильно иначе получиш отгоревшие распылы на форсунках и перегретую бошку
а по регенерации если в автоматическом режиме не прошла то можно и нужно зделать принудительно и ездить дальше также можно снять бочку и продуть воздухом это поможет при принудительном прожиге
и не торопись удалять егр и сажевый можеш хапнуть горя
SAM пишет:sync79 пишет:если удалять ЕГР то правильно иначе получиш отгоревшие распылы на форсунках и перегретую бошку
А правильно это как? Тут есть тема, где все подробно с фотографиями расписано. Или еще подводные камни есть?
Вчера, кстати и чек пропал. Но это же не дело, что машина так на мороз реагирует.
🤢 человек заходит на форум в первый раз и вместо "здраствуйте" начинает учить жить. И пох ему на многолетний опыт (я не про наш, я про американский)sync79 пишет:если удалять ЕГР то правильно иначе получиш отгоревшие распылы на форсунках и перегретую бошку
потрудись найтиsync79 пишет:ссылку можеш на тему
Если тревожат сомненья - не делай. Я тебе ЕГР и ДПФ, когда кончатся твои, с удовольствием продам.SAM пишет:sync79 пишет:если удалять ЕГР то правильно иначе получиш отгоревшие распылы на форсунках и перегретую бошку
555 (Сергей) пишет:🤢 человек заходит на форум в первый раз и вместо "здраствуйте" начинает учить жить. И пох ему на многолетний опыт (я не про наш, я про американский)sync79 пишет:если удалять ЕГР то правильно иначе получиш отгоревшие распылы на форсунках и перегретую бошку
Клубни, читайте Бразу, в не этого залетного казачка на тайоте.
