E777TE#1
Пробил рэмчика по recall и получил кучу новостей:
afety Recalls (What is a Safety Recall? Learn More)
Chrysler Recall # NHTSA Recall # Recall Date Safety Defect/Non Compliance Description and Safety Risk Repair Description Recall Status
K08
10V-200 May 06, 2010 THE WIRELESS IGNITION NODE (WIN) RECEIVER MAY EXPERIENCE A CONDITION WHERE THE FREQUENCY OPERATED BUTTON INTEGRATED KEY (FOBIK) MAY BE REMOVED PRIOR TO PLACING THE AUTOMATIC TRANSMISSION GEAR SHIFT LEVER IN THE PARK POSITION. THIS COULD RESULT IN UNINTENDED VEHICLE MOVEMENT AND CAUSE A CRASH WITHOUT WARNING. THE WIRELESS IGNITION NODE RECEIVER MUST BE INSPECTED AND REPLACED IF NECESSARY. THE NEW WIN MUST BE PROGRAMMED AND ALL FOBIK TRANSPONDERS MUST BE PROGRAMMED SO THEY ARE ABLE TO INTERFACE WITH THE NEW WIN RECEIVER. VEHICLES EQUIPPED WITH A PREMIUM TIRE PRESSURE MONITORING (TPM) SYSTEM (SALES CODE XGM) MUST ALSO HAVE THE SPARE TIRE PRESSURE SENSOR IDENTIFICATION NUMBER AND LOCATION PROGRAMMED INTO THE NEW WIN RECEIVER. INCOMPLETE BUT REPAIR PARTS ARE AVAILABLE
N08
13V-038 February 13, 2013 THE REAR AXLE PINION NUT ON ABOUT 278,000 OF THE ABOVE VEHICLES MAY LOOSEN DUE TO UNDERSIZED PINION SHAFT SPLINES. A LOOSE PINION NUT COULD CAUSE THE REAR AXLE TO SEIZE OR CAUSE THE DRIVESHAFT TO SEPARATE RESULTING IN A LOSS OF MOTIVE POWER. EITHER SITUATION COULD CAUSE A CRASH WITHOUT WARNING. THE REAR AXLE PINION NUT MUST BE INSPECTED. REAR AXLES FOUND WITH A LOOSE PINION NUT AND/OR A SEIZED UP REAR AXLE ASSEMBLY MUST BE RECONDITIONED. REAR AXLES WITH A 6-POINT PINION NUT THAT HAS NOT LOOSENED WILL HAVE A PINION NUT RETAINER INSTALLED. ALL REAR AXLES WITH A 12-POINT PINION NUT REQUIRE NO ADDITIONAL REPAIRS. INCOMPLETE BUT REPAIR PARTS ARE AVAILABLE
Campaigns (What is a Campaign? Learn More)
Campaign Date Campaign Description Repair Description Comments
January 01, 0001 REPROGRAM HVAC CONTROL HEAD & INSP./REPL. ACTUATOR
VEHICLES MUST HAVE UPDATED HVAC CONTROL HEAD SOFTWARE INSTALLED AND THE MODE DOOR ACTUATORS MUST BE TESTED AND REPLACED AS REQUIRED. INCOMPLETE BUT REPAIR PARTS ARE AVAILABLE
January 01, 0001 OUTER TIE ROD ENDS
BOTH OUTER TIE ROD ENDS MUST BE REPLACED. INCOMPLETE BUT REPAIR PARTS ARE AVAILABLE
K08
N08
