Ozzy#1
5000 usd
СОСТОЯНИЕ ИДЕАЛЬНОЕ 4 ИЗ 5
http://www.bowers-wilkins.com/Downloads/Product/Archive/ENG_FP10062_802-S3_info_sheet.pdf
Drive Units
Frequency Response
Sensitivity
Nominal Impedance
3 way vented-box system
1 x 25mm metal dome - high frequency
1 x 126mm Kevlar® - midrange
2 x 180mm Cobex® - bass
42Hz – 20kHz ± 3dB on reference axis
90dB spl(2.83V 1m)
8 ohms (minimum 3.4 ohms)
Power Handling
Dimensions
Finish
50W – 250W into 8 ohms on
unclipped programme
Height: 1040mm Width: 300mm
Depth: 370mm
Walnut,
Grille: Black Cloth
Апгрейд ---взял Montana WAS!!!
Drive Units
Frequency Response
Sensitivity
Nominal Impedance
90dB spl(2.83V 1m)
Power Handling
Dimensions
Finish
unclipped programme
Depth: 370mm
Walnut,
Grille: Black Cloth
