Из 12-ти летнего опыта использования обоих вариантов надёжность одинаковая, никогда никаких проблем с электронной раздаткой (GMC Yukon Denali - 400 тыс км) не было.
4L - только с полной остановкой и через нейтраль АКПП
неправильно батенька))
4л - на скорости 5км.ч нейтраль на руле и быстренько переключаешь на 4л,но также мона и при остановке,только иногда сложно воткнуть
With the vehicle rolling at 2 to 3 mph (3 to 5 km/h), shift
an automatic transmission to N (Neutral) or depress the
clutch on a manual transmission. While the vehicle is
coasting at 2 to 3 mph (3 to 5 km/h), shift the transfer
case lever firmly to the desired position. Do not pause in
transfer case N (Neutral).
NOTE: Shifting into or out of 4L is possible with the
vehicle completely stopped, however difficulty may occur
due to the mating clutch teeth not being properly
aligned. Several attempts may be required for clutch
teeth alignment and shift completion to occur. The preferred
method is with the vehicle rolling 2 to 3 mph (3 to
5 km/h). Avoid attempting to engage or disengage 4L
with the vehicle moving faster than 2 to 3 mph (3 to 5
km/h).
NOTE: Do not attempt to shift to or from 4L while the
transmission is in gear or clutch is engaged.
Transfer Case Reminder Light
The four-wheel-drive operating light (4WD), located in
the instrument cluster, is used to alert the driver that the
front axle is fully engaged and all four wheels are
driving.
нейтраль на руле это и есть нейтраль акпп , а катится 5 км это по желанию .
