Архив клуба / Форум / Электрика и электроника / Програмирования ключа?
Раздел «Электрика и электроника». Тема открыта 3 февраля 2010 года, в ней 10 сообщений.
MihailNik#1
кто нибудь знает алгоритм програмирования ключа? 2006г есть два прописанных ключа...
Volk686#2
А в мануале не написано?
Andrey#3
на третьем году так...
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
😎 The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector."
MihailNik#4
как в мануале пробовал ни хера не прописывается...
Customer Key Programming
You can program new keys to the system if you have two
valid keys by doing the following:
1. Insert the first valid key into the ignition and turn the
ignition to the ON position for at least 3 seconds but no
longer than 15 seconds. Turn the ignition back to the OFF
position and remove the first key.
2. Insert the second valid key and switch the ignition to
the ON position within 15 seconds. After 10 seconds the
Security Light will begin to flash. Turn the ignition back
to the OFF position and remove the second key.
3. Insert a blank Sentry Key into the ignition and switch
the ignition to the ON position within 60 seconds of
having removed the second key. After 10 seconds the
Security Light will stop flashing, then turn on for 3
seconds; then turn off.
The new Sentry Key has been programmed. The Keyless
Entry Transmitter will also be programmed during this
procedure. Repeat this process to program up to an
additional 6 keys. A maximum of 8 keys can be programmed
to the system, including the original keys
provided with the vehicle.
токо входит он в режим програмирования не со второго ключа а когда по второму кругу вставляю первый так 1-2-1 лампочка наченает моргать через 60 секунд пик и все...может это конечно какой нибудь другой режим....но как я понял ет прописание иммобилайзера а как сигналку прописать тогда... 😕
Andrey#5
а ключи паминять?
Jeep-usa#6
Ключи прописать можно только дилерским прибором при наличии пин кода или взломав программу.Если есть вопросы задавайте
Ленчик#7
😑 Я тут по весне уже задавала... Авто пришло с одним ключём, что краааайне напрягает, т.к. потеряв оный, не дай БОГ!!! ... можно остаться в ...пе.
Предложенные диллером 7,5 т. руб. к оплате за новый чип - напрягли:
1) дорого для меня на тот момент,
2) Карапуз сказал, что слишком дёшево, могут впарить туфту...
как быть? второй брелок, пришедший с машиной, в Крайслере сказали - не рабочий.
Jeep-usa#8
У нас ключ 2006 года и моложе с програмированием стоит всего-то 6500руб 😆
Ленчик#9
Ну, значит, мы идём к Вам... не кипятим... 😛
когда бапки будут....
Car-a-puzz#10
+1, без ПИНа и дилерского "тетриса" там делать нечего!
