Все запуталось в умище, что это значит
P0032 Dodge - O2 Sensor 1/1 Heater Circuit High 0 | Add Comment
Possible causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 harness is open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Faulty Engine Control Module (ECM)
What does this mean?
When is the code detected?
The P0032 is set when the ECM detects an excessively high voltage through the heated oxygen sensor heater circuit
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P0032 Dodge Description
Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM).
In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground.
The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
Read more:
http://engine-codes.com/p0032_dodge.html#ixzz3LDBeMsVi
P0032 Dodge - O2 Sensor 1/1 Цепи Нагревателя Высокая 0 | Добавить Комментарий
Возможные причины
- Неисправен Подогрев кислородного датчика (H2OS) Банк 1 Датчик 1
- Подогреваемый Датчик кислорода (H2OS) Банк 1 Датчик 1 жгут открыт замкнут на землю
- Подогреваемый Датчик кислорода (H2OS) Bank 1 Sensor 1 circuit плохое электрическое соединение
- Подогреваемый Датчик кислорода (H2OS) Bank 1 Sensor 1 circuit fuse
- Неисправен модуль управления двигателем (ECM)
Фото на vfl.ru
