Комплектация ST/SLT
Подвеска и система охлаждения Heavy Duty
Кондиционер
ABS ESP
Стеклоподъемники, электрозеркала
Air bag фронтальные+шторки
приемник с MP3
6 мест обивка кожзам Heavy Duty
круиз контроль
диски на 20 дюймов хром от Sport с новой резиной good year
брезентовая шторка на кузове
http://www.truckaccessorizer.com/store/access_cover_limited_edition.htm
APAS Monotone Paint BABS 160 Amp Alternator BC6S 625 Amp Maintenance Free Battery
BNBS Electronic Stability Control BRTS Anti-Lock 4-Wheel Disc Brakes CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags CG3S Advanced Multistage Front Air Bags** CKJS Black Vinyl Floor Covering
CSPS Driver/Passenger Assist Handles CTLS Base Door Trim Panel CUES Rear Underseat Compartment Storage
DH5S Elec Shift-on-the-Fly P/Time T/Case DJMS 205MM HD Front Axle DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle DS7S Conventional Differential Frt Axle DS8S Conventional Differential Rear Axle
GACS Tinted Glass Windows GJDS Rear Fixed Window GNAS Rear View Day/Night Mirror
GT6S Power Heated Mirrors, Fold-Away GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning
HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation JAYS Instrument Cluster w/Tach
JBFS Instrument Panel Black Bezel JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet JKYS Power Accessory Delay
JPBS Power Locks JP3S Pwr Front Windows, 1-Touch,Up Down LABS Tire Pressure Monitoring Warning LP
LCHS Rear Dome Lamp LMAS Halogen Headlamps LMGS Automatic Headlamps
LPES Cargo and CHMSL Lamp MBZS Dark Gray Rear Bumper w/Step Pads MCCS Gray Front Bumper
MCLS Gray Upper Fascia MDAS Front License Plate Bracket MENS Front Wheel Spats
MFDS Bright Grille MGAS Ram's Head Badge MHLS MOPAR Rear Wheel Well Liners
MNAS Black Door Handles MS2S Ram 1500 Badge MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches MXCS Front Bumper Sight Shields NFWS 26 Gallon Fuel Tank
QW1S Stone White C/C RCGS 6 Speakers RESS Uconnect 130 AM/FM/CD/MP3
SBAS Power Rack and Pinion Steering SCFS 4-Spoke Steering Wheel SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch
WEAS 17X7.0 Steel Argent Wheels WF1S 17 Steel Spare Wheel XA8S Non Adjustable Pedals
XBSS Pickup Box XFKS 7 Pin Wiring Harness XFUS Trailer Tow w/4-Pin Connector Wiring
XJJS Locking Tailgate X81S Instrument Panel Parts Module X82S Door Parts Module
X83S Front End Parts Module X88S Tire Wheel Parts Module YAAS Build To U.S. Mkt. Specifications
Z6GS GVW Rating - 6700# 1APS U.S. Fleet Purchase 142S Zone 42-Detroit
5BAS DS/6322 Vehicle Family 5I4S Four Wheel Drive (4WD)/(4X4) 5I7S Price Class L
5RHS 2009 Vehicle Specifications 5ZES 6 FT. Cargo Box 5ZKS Quad Cab
5ZLS 1500 Series 594S Vehicle Order Tracking 6USS U.S. Specifications Label
639S Pennsylvania Ship to State Code 7BBS Carb. Code 02 7CDS Smog Code 04
915S Indiana Sold to State Code
Optional Equipment
*TX HD Vinyl 40/20/40 Split Bench Seat -V3 Dark Slate/Medium Graystone CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat CJ2P Supp. Side Curtain Frt/Rr Air Bags CL8P Delete Floor Mats
DGQ 5-Spd Automatic 545RFE Transmission EVE 4.7L V8 FFV Engine GVBC All Vehicles W/Power Mirrors
JP8P Manual Adjust Seats LE4P Black Exterior Mirrors MPPP Rear Wheel Spats
NAS 50 State Emissions NHDP Heavy Duty Transmission Oil Cooler NHJP Exterior Mirrors w/Heating Element
NHM Speed Control NMCP Heavy Duty Engine Cooling NZDP Next Generation Engine Controller
PW1 Stone White Clear Coat RAAC All Radio Equipped Vehicles RDDP Fixed Long Mast Antenna
TTL LT275/70R17C OWL All Terrain Tires TZAP Goodyear Brand Tires WLYC All Steel Wheels
WMJP Center Hub XBNP Tip Start XKNA Flex Fuel Vehicle
YGEA 5 Additional Gallons of Gas ZBTP Spring - Left Rear ZEAP Spring - Left Front
ZNSP Spring - Right Rear ZTAP Spring - Right Front 0ADA FAM: DS TRACKING: 80723T00 MY:2009
