Сергор пишет:
Не помогло это видио! У меня другая настройка, т.е голосовая!
Phone Pairing
NOTE: Pairing is a one-time initial setup before using the phone. You will also
need to follow the Bluetooth ® instructions in your cell phone user guide to
complete the phone pairing setup.
• Press the Phone button to begin.
• Wait for the “ready” prompt and BEEP.
• (After the BEEP), say “Uconnect setup”.
• (After the BEEP), say “phone pairing”.
• (After the BEEP), say “pair a phone”.
• Follow the audible prompts.
• You will be asked to enter a four-digit Personal Identification Number (PIN),
which you will later need to enter into your mobile phone. You can enter any
four-digit PIN. You will not need to remember this PIN after the initial pairing
process.
• You will then be prompted to give the phone pairing a name (each phone
paired should have a unique name).
• Next you will be asked to give this new pairing a priority of 1 thru 7 (up to
seven phones may be paired); 1 is the highest and 7 is the lowest priority. The
system will only connect to the highest priority phone that exists within the
proximity of the vehicle.
НАСТОЯТЕЛЬНО рекомендую найти кого-то из знакомых, кто хоть немного знает английский, ибо говорить нужно на английском!
ЗЫ: Там делов реально на 5 минут..а то и меньше..
