Here it is! Finally for all of you 2009 Dodge Ram 1500 Quad or Crew cab (ONLY )owners, as well as 2010-2013 Dodge Ram Quad and Crew cab owners is this new Kicker 10"subwoofer. This Mopar package contains detailed instructions on how to install this plug and play sytem. It contains one 10" subwoofer which installs easily in place of the rear driver side portion of your fold flat storage space. The amp (not pictured) installs easily on the bottom of your steering column (knee area) which is hidden from view once you put the lower dash portion back into place. Premium base sound with 200 amps/watts. Now you can take your Rams sound system to the next level while still retaining the stock look.
