dvk#1
Дали мне наводку на мультисканер , посмотрел описание, похоже что все функции дилерского сканера присутствуют..
и ценник вобщем не конский, думаю может прикупить в хозяйство? может кто уже сталкивался с таким оборудованием?
вот ссылка на сайт http://www.autoenginuity.com/products-software.html#EI04
и вот список функций..
Enhanced interface for Chrysler/Dodge/Plymouth/Eagle (EI04) 1996-2012* 2
Our enhanced Chrysler interface supports hundreds of sensors selected from the powertrain, body, chassis, and transmission system. It includes hi- and low-speed sensor support giving you more sensors and faster throughput then our competitors. This enhanced interface comes with its own hardware interface specifically designed for Chrysler SCI and CCD based controllers. By doing a stand-alone interface we can offer you more SCI coverage then our competitors who are limited by electrical issues with generic OBD-II. Also supported is the CR2 and CR3 Sprinter ('04 - '06), Jeep Liberty Diesel ('05 - '06), diesel Cummins engines, and the Venom equipped Vipers ('08+).
SBEC/JTEC System Tests:
EGR System Test
EVAP System Monitor Service Test
Erase All DTC Fault Codes
Generate Full Field Test
Gov & 3-4 Shift Valve Test - JTEC Only
Leak Detect Pump Test
Purge Vapors Test
Reset All Adaptive Memory Fuel Cells
Reset All Non-Volatile Memory
Reset CAM/Crank Misalignment
Reset CAM, Crank, and Sync Status Record
Reset Duty Cycle Monitor
Reset Engine Running Time Record
Reset Fuel Shut-off Record
Reset Intake Airflow Control Stepper Motor Position
Reset Trip Information
Set Sync Signal - JTEC Only
Set Minimum Throttle Position to Maximum
Torque Converter Clutch Test - JTEC Only
VPW-based System Tests:
ABS Bleed Brakes (EBC325, Mk20e, and Mk25e)
Tire Size Programming
Transmission Rear/Front Wheel Brake Torque Test
Transmission Pump Test
Transmission Quick Learn
Transmission TCC Break-In Test
Transmission Front Wheel Pinion Factor
NGC System Tests:
Injector Kill Test
NVLD Force Monitor Test
Purge Vapor Tests
Reset all On-Board Control Units
Report Part Number
Report Reflash Program Counter
CAN-based Module System Test and Configuration Support:
ABS Brake Bleed
ABS Initalize ECU
Auto Door Locks
Beltminder
Cylinder Performance Test
Current VIN Progamming
CAM and Crank Relearn
DRL Setup Configuration
EATX Quick Learn
Engine On Odometer
IMA Programming Injestors
Injector Quantity Adjustment
Module Configuration Setup
Retrieve Installed Module VINs
Tire Pressure Sensor ID Programming
Tire Pressure Trigger Configuration
Tire Pressure Pressure Calibration
цена вопроса 250 долларов базовый usb комплект для подключения к ноуту +
расширение допустим для того же крайслера 230 долларов..
вполне так бюджетно выходит..
EGR System Test
Purge Vapors Test
NGC System Tests:
Injector Kill Test
Purge Vapor Tests
Report Part Number
ABS Brake Bleed
ABS Initalize ECU
Auto Door Locks
Beltminder
EATX Quick Learn
Engine On Odometer
