Nuclear Blast#1
Производства bushwacker - соответственно usa.
Цена - 500$ в Москве.
Самовывоз из Химок.
возможна установка.
контакты 8 (926) ***-**-** Владимир.
8 (903) ***-**-** Алексей.
The fender flares specifications are:
1. ABS Plastic (Black)
2. Size: The flares will cover 4.0 inches (height) of the fender and extend out 3.25 (width) inch from the fender.
2. There is NO DRILLING REQUIRED.
3. It comes with all the mounting hardwares and the rubber seal strip with the geniune 3M automotive tape.
4. It comes with instructions, and all you need is a philips screwdriver and or allen wrench.
5. Most importantly, you can install this yourself and in 10 minutes or less.
6. Uses all factory mounting locations, no possible way of damaging your vehicle during installation.
7. It has 100% UV Protection, no chalking, no cracking, no warping.
8. It is a single-piece design and construction.
9. It has integrated designs that complements the vehicle's original body lines.
10. Fits great with stock wheels and tires or aftermarket larger wheels and tires.
11. Focuses on the style and looks of your vehicle.
12. OEM STYLE means it is similar to OEM size and shape, but is not OEM.
Самовывоз из Химок.
возможна установка.
